Salta al contenuto principale
LG EnV VX9900 LCD Screen Replacement
Cosa ti serve
  1. LG EnV VX9900 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. LG EnV VX9900 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. LG EnV VX9900 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the battery.
  4. LG EnV VX9900 LCD Screen Replacement, Circuit Board and Full Key Board: passo 4, immagine 1 di 2 LG EnV VX9900 LCD Screen Replacement, Circuit Board and Full Key Board: passo 4, immagine 2 di 2
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  5. LG EnV VX9900 LCD Screen Replacement: passo 5, immagine 1 di 1
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  6. LG EnV VX9900 LCD Screen Replacement: passo 6, immagine 1 di 2 LG EnV VX9900 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Open the phone.
  7. LG EnV VX9900 LCD Screen Replacement: passo 7, immagine 1 di 2 LG EnV VX9900 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  8. LG EnV VX9900 LCD Screen Replacement: passo 8, immagine 1 di 2 LG EnV VX9900 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Gently pry and detach the connection located near the hinge with fingers.
  9. LG EnV VX9900 LCD Screen Replacement: passo 9, immagine 1 di 2 LG EnV VX9900 LCD Screen Replacement: passo 9, immagine 2 di 2
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
  10. LG EnV VX9900 LCD Screen Replacement, LCD Screen: passo 10, immagine 1 di 1
    • After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
  11. LG EnV VX9900 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Careful! The paint is easy to scratch.
    • Remove the 4 screw covers from top piece of phone by using a Push Pin.
  12. LG EnV VX9900 LCD Screen Replacement: passo 12, immagine 1 di 1
    • Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
  13. LG EnV VX9900 LCD Screen Replacement: passo 13, immagine 1 di 3 LG EnV VX9900 LCD Screen Replacement: passo 13, immagine 2 di 3 LG EnV VX9900 LCD Screen Replacement: passo 13, immagine 3 di 3
    • Be careful while breaking the adhesive connecting the speaker and the casing in the following sub step so that you do not tear any wires.
    • Pry open the colored casing using the Plastic Pry Tool.
    • Remove the number pad and place it to the side.
  14. LG EnV VX9900 LCD Screen Replacement: passo 14, immagine 1 di 2 LG EnV VX9900 LCD Screen Replacement: passo 14, immagine 2 di 2
    • Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
  15. LG EnV VX9900 LCD Screen Replacement: passo 15, immagine 1 di 1
    • The pieces connected by wires are magnets and are removable.
    • Remove the LCD Screen.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 15-15, Forte Spring 2012 Membro di Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,267
