Salta al contenuto principale
LG Dare Logic Board Replacement
Cosa ti serve
  1. LG Dare Logic Board Replacement, Battery: passo 1, immagine 1 di 2 LG Dare Logic Board Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Logic Board Replacement: passo 2, immagine 1 di 3 LG Dare Logic Board Replacement: passo 2, immagine 2 di 3 LG Dare Logic Board Replacement: passo 2, immagine 3 di 3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Logic Board Replacement, Logic Board: passo 3, immagine 1 di 2 LG Dare Logic Board Replacement, Logic Board: passo 3, immagine 2 di 2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Logic Board Replacement: passo 4, immagine 1 di 3 LG Dare Logic Board Replacement: passo 4, immagine 2 di 3 LG Dare Logic Board Replacement: passo 4, immagine 3 di 3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Logic Board Replacement: passo 5, immagine 1 di 3 LG Dare Logic Board Replacement: passo 5, immagine 2 di 3 LG Dare Logic Board Replacement: passo 5, immagine 3 di 3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Logic Board Replacement: passo 6, immagine 1 di 1
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Logic Board Replacement: passo 7, immagine 1 di 3 LG Dare Logic Board Replacement: passo 7, immagine 2 di 3 LG Dare Logic Board Replacement: passo 7, immagine 3 di 3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Logic Board Replacement: passo 8, immagine 1 di 1
    • Open the USB port cover.
  9. LG Dare Logic Board Replacement: passo 9, immagine 1 di 3 LG Dare Logic Board Replacement: passo 9, immagine 2 di 3 LG Dare Logic Board Replacement: passo 9, immagine 3 di 3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
Conclusione
To re-assemble your device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Haoyan Huang
Membro da: 01/26/12
139 Reputazione
4 Guide realizzate
Cal Poly, Team 9-4, Regan Winter 2012 Membro di Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,158
