Cosa ti serve
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
Quasi finito!
Conclusione
