Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly. The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
Aggiungi Commento
Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
  • Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
Aggiungi Commento
Pry the case off using a plastic opening tool. Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo. The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  • Pry the case off using a plastic opening tool.
    • Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
Aggiungi Commento
Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it. Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
Aggiungi Commento
Pry off the plastic tabs that cover two screws, as shown in the first picture. Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
Aggiungi Commento
Pry off the back cover from the front of the case using a plastic opening tool.
  • Pry off the back cover from the front of the case using a plastic opening tool.
Aggiungi Commento
Unscrew the 4 screws that hold the sliding mechanism in place.
  • Unscrew the 4 screws that hold the sliding mechanism in place.
Aggiungi Commento
Remove sliding mechanism.
  • Remove sliding mechanism.
Aggiungi Commento
Conclusione
Thomas
Membro da: 18/01/2013
88 Reputazione
8 Guide realizzate
Cal Poly, Team 19-46, Regan Winter 2013 Membro di Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 230
