Introduzione
Outline what you are going to teach someone how to do.
Parti
Nessuna parte richiesta.
Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly. The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
Aggiungi Commento
Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
  • Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
Aggiungi Commento
Pry the case off using a plastic opening tool. Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo. The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  • Pry the case off using a plastic opening tool.
    • Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
Aggiungi Commento
Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it. Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
Aggiungi Commento
Pry off the plastic tabs that cover two screws, as shown in the first picture. Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
Aggiungi Commento
Pry off the back cover from the front of the case using a plastic opening tool.
  • Pry off the back cover from the front of the case using a plastic opening tool.
Aggiungi Commento
Pry the front speaker and wireless receiver out of the front case using a spudger. They may be taped into the case, so don't be afraid to pry hard. They may be taped into the case, so don't be afraid to pry hard.
  • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
Aggiungi Commento
Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case. Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
Aggiungi Commento
Unhook the ribbon cable using that flat side of a spudger.
  • Unhook the ribbon cable using that flat side of a spudger.
Aggiungi Commento
Next, carefully remove the tape from the LCD board.
  • Next, carefully remove the tape from the LCD board.
Aggiungi Commento
Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger. The LCD Board in now accessible.
  • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
  • The LCD Board in now accessible.
Aggiungi Commento
Conclusione
Thomas
Membro da: 18/01/2013
88 Reputazione
8 Guide realizzate
Cal Poly, Team 19-46, Regan Winter 2013 Membro di Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 215
