Introduzione
Use this guide to replace the side buttons. Be prepared to deal with small parts, including screws and the buttons themselves.
Turn the phone off before starting the replacement process.
  • Turn the phone off before starting the replacement process.
  • Place the phone face down.
  • Press your finger down on the indentation and slide the back plate off.
Aggiungi Commento
Using your index finger lift and remove the battery from the phone. Using your index finger lift and remove the battery from the phone. Using your index finger lift and remove the battery from the phone.
  • Using your index finger lift and remove the battery from the phone.
Aggiungi Commento
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
  • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
  • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
Aggiungi Commento
Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
  • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
  • If needed, use tweezers to remove loose screws from the recessed holes.
  • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
Aggiungi Commento
Pull the rear case up using the spudger. The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
  • Pull the rear case up using the spudger.
  • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
  • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
Aggiungi Commento
Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
Aggiungi Commento
Carefully remove the rear case from the phone. Carefully remove the rear case from the phone.
  • Carefully remove the rear case from the phone.
Aggiungi Commento
Use tweezers to remove the music button found on the side of the phone.
  • Use tweezers to remove the music button found on the side of the phone.
Aggiungi Commento
Use tweezers to remove the volume control buttons on the opposite side of the phone. Use tweezers to remove the volume control buttons on the opposite side of the phone.
  • Use tweezers to remove the volume control buttons on the opposite side of the phone.
Aggiungi Commento
Conclusione
Brenna Yagade
Membro da: 15/04/2013
22 Reputazione
12 Guide realizzate
Cal Poly, Team 12-35, Amido Spring 2013 Membro di Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 137
