Salta al contenuto principale
LG Chocolate 3 Rear Case Replacement
Cosa ti serve
  1. LG Chocolate 3 Rear Case Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Rear Case Replacement: passo 2, immagine 1 di 3 LG Chocolate 3 Rear Case Replacement: passo 2, immagine 2 di 3 LG Chocolate 3 Rear Case Replacement: passo 2, immagine 3 di 3
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Rear Case Replacement, Rear Case: passo 3, immagine 1 di 1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Rear Case Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Rear Case Replacement: passo 5, immagine 1 di 2 LG Chocolate 3 Rear Case Replacement: passo 5, immagine 2 di 2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Rear Case Replacement: passo 6, immagine 1 di 1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Rear Case Replacement: passo 7, immagine 1 di 2 LG Chocolate 3 Rear Case Replacement: passo 7, immagine 2 di 2
    • Carefully remove the rear case from the phone.
Conclusione
Cal Poly, Team 12-35, Amido Spring 2013 Membro di Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 287
