Introduzione
The front housing is the glossy front cover of the phone which can get scratched easily.
Parti
Nessuna parte richiesta.
Insert one of the plastic opening tools between the silver and plastic black parts of the speaker at the top of the phone. Pry off the black plastic part to separate it from the silver part.
  • Insert one of the plastic opening tools between the silver and plastic black parts of the speaker at the top of the phone.
  • Pry off the black plastic part to separate it from the silver part.
Aggiungi Commento
Use the screwdriver to remove four 3.0 mm Phillips #00 screws as shown.
  • Use the screwdriver to remove four 3.0 mm Phillips #00 screws as shown.
Aggiungi Commento
Insert a the plastic opening tool in between the silver and black seam of the phone casing. Take off the front housing by running the plastic opening tool around the perimeter of the phone.
  • Insert a the plastic opening tool in between the silver and black seam of the phone casing.
  • Take off the front housing by running the plastic opening tool around the perimeter of the phone.
Aggiungi Commento
Conclusione
Zack Mintzer
Membro da: 16/04/2013
1 Reputazione
12 Guide realizzate
Cal Poly, Team 21-55, Johann Spring 2013 Membro di Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 308
