Introduzione
How to remove the display screen from an LG CG180 cell phone.
Power down the cell phone by pressing and holding down the red "end call" button.
  • Power down the cell phone by pressing and holding down the red "end call" button.
Aggiungi Commento
Turn the phone screen-down so you are looking at the back cover.
  • Turn the phone screen-down so you are looking at the back cover.
Aggiungi Commento
Slide the back cover down using your finger to remove the cover from the phone. Slide the back cover down using your finger to remove the cover from the phone.
  • Slide the back cover down using your finger to remove the cover from the phone.
Aggiungi Commento
Place your finger at the top of the battery in small gap.
  • Place your finger at the top of the battery in small gap.
Aggiungi Commento
Press downward while pulling outward to remove the battery.
  • Press downward while pulling outward to remove the battery.
Aggiungi Commento
Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
Aggiungi Commento
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Insert a plastic opening tool in the seam.
  • Insert a plastic opening tool in the seam.
Aggiungi Commento
Run the tool along the seam to release all the tabs. Run the tool along the seam to release all the tabs.
  • Run the tool along the seam to release all the tabs.
Aggiungi Commento
Pull the phone back cover off once all the tabs are released. Pull the phone back cover off once all the tabs are released.
  • Pull the phone back cover off once all the tabs are released.
Aggiungi Commento
Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
Aggiungi Commento
The hardshell case is separated from the rest of the phone.
  • The hardshell case is separated from the rest of the phone.
Aggiungi Commento
Separate keypad from circuit board by turning it upside down and allowing it to fall off. Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
Aggiungi Commento
Place the circuit board with the display facing downward.
  • Place the circuit board with the display facing downward.
Aggiungi Commento
Use thumb to release both white clips at the top of the circuit board.
  • Use thumb to release both white clips at the top of the circuit board.
  • Be careful with the display because it is still attached by electrical tape.
Aggiungi Commento
Once both clips are released, turn over the circuit board so that the display is facing upward. Carefully lift the display from the left side and open to the right.
  • Once both clips are released, turn over the circuit board so that the display is facing upward.
  • Carefully lift the display from the left side and open to the right.
Aggiungi Commento
Carefully remove the electrical tape from the display.
  • Carefully remove the electrical tape from the display.
Aggiungi Commento
The display is disconnected from the circuit board.
  • The display is disconnected from the circuit board.
Aggiungi Commento
Conclusione
Alex Jacobs
Membro da: 21/01/2010
5 Reputazione
8 Guide realizzate
Cal Poly, Team 14-42, Regan Winter 2010 Membro di Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,660
