Introduzione
Your phone uses a spring to help make the keypad slide in and out seamlessly. It is located between the front and back case. In this guide you will learn how to separate the front case from the sliding portion
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward. On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Aggiungi Commento
Lift and remove the battery.
  • Lift and remove the battery.
Aggiungi Commento
Remove the two screw covers at the top of phone with tweezers. Remove the two screw covers at the top of phone with tweezers.
  • Remove the two screw covers at the top of phone with tweezers.
Aggiungi Commento
Remove the six Phillips #000 (3mm) screws.
  • Remove the six Phillips #000 (3mm) screws.
Aggiungi Commento
Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone. The plastic side buttons fall out when you take the back cover off. The back cover is connected to the speaker by red and black wires.
  • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
  • The plastic side buttons fall out when you take the back cover off.
  • The back cover is connected to the speaker by red and black wires.
Aggiungi Commento
Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
  • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
  • Set the back cover with the speaker aside.
Aggiungi Commento
Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel. An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
  • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
Aggiungi Commento
Gently remove the blue transparent tape from the connector.
  • Gently remove the blue transparent tape from the connector.
Aggiungi Commento
With the plastic opening tool, gently pry the LCD connector from the motherboard.
  • With the plastic opening tool, gently pry the LCD connector from the motherboard.
  • Set the motherboard aside.
Aggiungi Commento
Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
Aggiungi Commento
Gently pull the orange ribbon from the number pad casing.
  • Gently pull the orange ribbon from the number pad casing.
  • Set the number pad case to the side once it is detached from the ribbon.
Aggiungi Commento
Remove the two red sticker screw coverings at the top corners with tweezers.
  • Remove the two red sticker screw coverings at the top corners with tweezers.
Aggiungi Commento
Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
Aggiungi Commento
Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone. Set the red sliding backing and front cover to the side.
  • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
  • Set the red sliding backing and front cover to the side.
Aggiungi Commento
Conclusione
Cal Poly, Team 4-27, Amido Fall 2013 Membro di Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 275
