Introduzione
To isolate the LCD screen, one needs to be gentle with separating parts and removing screws from the camera.
Parti
Nessuna parte richiesta.
Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
  • Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
Aggiungi Commento
Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together. To get to the second screw, rotate the screen.
  • Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
  • To get to the second screw, rotate the screen.
Aggiungi Commento
Gently peel off the front and back cover of the screen. Peel back the plastic cover. Peel back the plastic cover.
  • Gently peel off the front and back cover of the screen.
  • Peel back the plastic cover.
Aggiungi Commento
Gently pull off the screen from the base.
  • Gently pull off the screen from the base.
  • A small metal piece between the screen cover and the screen may fall out during repair. Remember to replace it with the rounded corners facing away from the screen during reassembly.
  • This takes a little force.
Aggiungi Commento
Unplug the wires that are attaching the screen to the circuit board.
  • Unplug the wires that are attaching the screen to the circuit board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
konrad
Membro da: 11/01/2011
214 Reputazione
3 Guide realizzate
Cal Poly, Team 7-31, Regan Winter 2011 Membro di Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Membri
6 Guide realizzate
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,276
