Introduzione
This guide will teach you how to replace the keyboard of the Kyocera Marbl K127 cell phone. This is useful in the event that the keyboard buttons will not work or are worn and no longer have visible numbers and markings. The process involves five easy steps from start to finish.
Parti
Nessuna parte richiesta.
Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover. Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover. Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
  • Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
Aggiungi Commento
Use your index finger at the top of the battery and pull it towards your body. Use your index finger at the top of the battery and pull it towards your body. Use your index finger at the top of the battery and pull it towards your body.
  • Use your index finger at the top of the battery and pull it towards your body.
Aggiungi Commento
Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard. Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard. Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard.
  • Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard.
Aggiungi Commento
Lift the motherboard away from you to locate the existing keyboard and remove it. Lift the motherboard away from you to locate the existing keyboard and remove it. Lift the motherboard away from you to locate the existing keyboard and remove it.
  • Lift the motherboard away from you to locate the existing keyboard and remove it.
Aggiungi Commento
Hold the new keyboard in your hand facing you as it would look in your cell phone, lift the motherboard with your opposite hand, and then flip the keyboard face down and fit it in to place. Hold the new keyboard in your hand facing you as it would look in your cell phone, lift the motherboard with your opposite hand, and then flip the keyboard face down and fit it in to place. Hold the new keyboard in your hand facing you as it would look in your cell phone, lift the motherboard with your opposite hand, and then flip the keyboard face down and fit it in to place.
  • Hold the new keyboard in your hand facing you as it would look in your cell phone, lift the motherboard with your opposite hand, and then flip the keyboard face down and fit it in to place.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 97
