Introduzione
This guide will show you how to replace your front & back camera of your Kurio Touch 4S
Make sure to open the back cover easily using the plastic opening tool.
  • Make sure to open the back cover easily using the plastic opening tool.
Aggiungi Commento
Remove back cover by prying away from the Kurio. The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides. The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  • Remove back cover by prying away from the Kurio.
  • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
Aggiungi Commento
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
Aggiungi Commento
After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  • All these screws are identical so don't worry if you miss them up.
Aggiungi Commento
Remove the battery because it blocks the plastic shield that covers the camera.
  • Remove the battery because it blocks the plastic shield that covers the camera.
  • Do not remove the wires that are attached to the battery and the motherboard.
Aggiungi Commento
Remove the plastic cover that is covering the camera area using tweezers.
  • Remove the plastic cover that is covering the camera area using tweezers.
Aggiungi Commento
Separate the two halves of your Kurio Touch 4S. Gently use a brush to remove any dirt or finger prints around the area.
  • Separate the two halves of your Kurio Touch 4S.
  • Gently use a brush to remove any dirt or finger prints around the area.
  • Use the Tweezers to detach the front and back camera from its place.
Aggiungi Commento
Remove the copper wires by using the Tweezers to replace your new camera. Remove the copper wires by using the Tweezers to replace your new camera.
  • Remove the copper wires by using the Tweezers to replace your new camera.
Aggiungi Commento
Conclusione
Khalid AlTamimi
Membro da: 21/01/2015
251 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Brown Winter 2015 Membro di USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 199
