Introduzione
This guide displays the steps to follow to replace the camera on the Kurio 7 children tablet. This is a delicate procedure, and be careful not to pull any wires out during the replacement process.
Begin by removing the rubber cover from the Kurio 7. Begin by removing the rubber cover from the Kurio 7. Begin by removing the rubber cover from the Kurio 7.
  • Begin by removing the rubber cover from the Kurio 7.
Aggiungi Commento
Remove the  four 30 mm Phillips #00 screws from the outer case. Remove the  four 30 mm Phillips #00 screws from the outer case.
  • Remove the four 30 mm Phillips #00 screws from the outer case.
Aggiungi Commento
Insert the plastic opening tool in the gap between the front cover and the back cover of the device. Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
  • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
  • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
  • Be careful not to break off the tabs that hold the front cover and the back cover together.
Aggiungi Commento
Once all of the tabs are removed, the back cover should come off easily. Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
  • Once all of the tabs are removed, the back cover should come off easily.
  • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Aggiungi Commento
Use a plastic credit card, or other thin object, to separate the battery from the screen. Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
  • Use a plastic credit card, or other thin object, to separate the battery from the screen.
  • Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
  • Carefully set the battery aside.
Aggiungi Commento
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place. Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
  • Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Aggiungi Commento
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount. Pull the ribbon out of the mount. Pull the ribbon out of the mount.
  • Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
  • Pull the ribbon out of the mount.
Aggiungi Commento
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
  • There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
  • Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
  • To remove the ribbon from the mount, follow the same steps in Step 3.
Aggiungi Commento
Pull back the ribbons and put the battery near the bottom of the Kurio.
  • Pull back the ribbons and put the battery near the bottom of the Kurio.
  • The motherboard is now removed so that other components can be worked on.
Aggiungi Commento
Carefully remove the soft black tape that covers the camera. Keep the tape for the replacement steps.
  • Carefully remove the soft black tape that covers the camera. Keep the tape for the replacement steps.
Aggiungi Commento
To release the camera's ribbon, use the opening tool to pull on the black edges of the ribbon mount. Alternate sides until the ribbon is loose enough to pull out. Alternate sides until the ribbon is loose enough to pull out.
  • To release the camera's ribbon, use the opening tool to pull on the black edges of the ribbon mount.
  • Alternate sides until the ribbon is loose enough to pull out.
Aggiungi Commento
There may be hot glue holding down the front camera. Use the tweezers to carefully pull it off.
  • There may be hot glue holding down the front camera. Use the tweezers to carefully pull it off.
Aggiungi Commento
To remove the camera, grab the ribbon with tweezers and pull the camera through the mother board.
  • To remove the camera, grab the ribbon with tweezers and pull the camera through the mother board.
  • Do not pull on the ribbon hard, but try to line up the camera so that fits through the hole in the motherboard.
  • The camera is double sided, as the Kurio 7 have both a front and a back camera.
  • You have successfully removed the camera!
Aggiungi Commento
Conclusione
Replace with new camera. To reassemble your device, follow these instructions in reverse order.
Omri Nissan
Membro da: 16/04/2014
321 Reputazione
2 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2014 Membro di Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 643
