Introduzione
This guide demonstrates how to install a LCD.
Parti
Nessuna parte richiesta.
Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
Aggiungi Commento
Next, press down on the red lever which holds the battery in place.
  • Next, press down on the red lever which holds the battery in place.
Aggiungi Commento
Once the battery has popped out of the compartment, simply pull it out of the camera. Once the battery has popped out of the compartment, simply pull it out of the camera.
  • Once the battery has popped out of the compartment, simply pull it out of the camera.
Aggiungi Commento
Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides. Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera. Begin by removing the first screw located on the back of the camera.
  • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
  • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
  • Begin by removing the first screw located on the back of the camera.
Aggiungi Commento
Next, remove the two screws located on the right side of the camera. Next, remove the two screws located on the right side of the camera.
  • Next, remove the two screws located on the right side of the camera.
Aggiungi Commento
After removing the screws located on the right side, remove the six screws located on the bottom of the camera. After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
Aggiungi Commento
Lastly, remove the two screws located on the left side of the camera. Lastly, remove the two screws located on the left side of the camera.
  • Lastly, remove the two screws located on the left side of the camera.
Aggiungi Commento
Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover. Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures. Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
    • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
Aggiungi Commento
Apply pressure on the left and right side of the camera and pull the back cover away from the device. Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera. Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
  • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
  • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
Aggiungi Commento
Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures. Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
  • Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
Aggiungi Commento
Gently remove the LCD screen from it's interior casing by lifting and pulling from the right side.
  • Gently remove the LCD screen from it's interior casing by lifting and pulling from the right side.
  • Be incredibly cautious not to pull to hard on the screen, doing so may rip the ribbon that connects the screen to the logic board and permanently damage your camera.
Aggiungi Commento
To completely remove the LCD screen from the interior of the camera, you must unhook the ribbon from the logic board. To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen. To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen.
  • To completely remove the LCD screen from the interior of the camera, you must unhook the ribbon from the logic board.
  • To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen.
Aggiungi Commento
Conclusione
katie newman
Membro da: 28/10/2010
30 Reputazione
3 Guide realizzate
Cal Poly, Team 5-16, Maness Fall 2010 Membro di Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,586
