Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
Aggiungi Commento
Next, press down on the red lever which holds the battery in place.
  • Next, press down on the red lever which holds the battery in place.
Aggiungi Commento
Once the battery has popped out of the compartment, simply pull it out of the camera. Once the battery has popped out of the compartment, simply pull it out of the camera.
  • Once the battery has popped out of the compartment, simply pull it out of the camera.
Aggiungi Commento
Conclusione
Jack
Membro da: 10/10/2010
172 Reputazione
3 Guide realizzate
Cal Poly, Team 5-16, Maness Fall 2010 Membro di Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,637
