Parti
Nessuna parte richiesta.
Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
  • Place thumb firmly on battery cover.
  • Slide thumb right, the cover should follow and pop up.
Aggiungi Commento
Place thumb on orange tab and pull back towards screen. The battery should pop up.
  • Place thumb on orange tab and pull back towards screen.
  • The battery should pop up.
  • Gently lift battery out.
Aggiungi Commento
Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
  • Remove screws from along outer edge of casing.
  • There are 6 screws in total.
  • Righty tighty, lefty loosey!
Aggiungi Commento
Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
  • Gently lift off front and back casing.
Aggiungi Commento
Remove screws along side. Gently peel off side casing. Gently peel off side casing.
  • Remove screws along side.
  • Gently peel off side casing.
Aggiungi Commento
Conclusione
Kyanna
Membro da: 13/03/2014
313 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 76
