Introduzione
Replace unusable or damaged button.
Parti
Nessuna parte richiesta.
Open the battery cover.
  • Open the battery cover.
Aggiungi Commento
Slide the orange latch sideways to eject the battery.
  • Slide the orange latch sideways to eject the battery.
  • Remove the battery.
Aggiungi Commento
Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
  • Remove 7 screws.
    • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
    • 4 (4.45mm) screws on the bottom of the camera.
    • 2 (2.95mm) screws on the left side of the camera.
Aggiungi Commento
There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
Aggiungi Commento
Remove the rear camera casing. Remove the front casing.
  • Remove the rear camera casing.
  • Remove the front casing.
Aggiungi Commento
Remove the top panel screw (1x 4.37mm). Remove the top panel screw (1x 4.37mm).
  • Remove the top panel screw (1x 4.37mm).
Aggiungi Commento
Remove the top panel. Remove the top panel.
  • Remove the top panel.
Aggiungi Commento
Remove the back panel screws (1x 3.33mm, and  1x 3.40mm). Remove the back panel screws (1x 3.33mm, and  1x 3.40mm).
  • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
Aggiungi Commento
Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount.
  • Separate the inner casing from the tripod mount.
Aggiungi Commento
Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board.
  • Gently pull the orange tab out of the circuit board.
Aggiungi Commento
Carefully flip the LCD panel to expose the central circuit board. Carefully flip the LCD panel to expose the central circuit board.
  • Carefully flip the LCD panel to expose the central circuit board.
Aggiungi Commento
Remove the (1x 3.33mm) screw from the menu button panel .
  • Remove the (1x 3.33mm) screw from the menu button panel .
Aggiungi Commento
Pull the second orange tab from the circuit board and remove the buttons. Pull the second orange tab from the circuit board and remove the buttons.
  • Pull the second orange tab from the circuit board and remove the buttons.
Aggiungi Commento
Conclusione
Michael
Membro da: 24/06/2010
63 Reputazione
2 Guide realizzate
Cal Poly, Team 2-8, Johann Summer 2010 Membro di Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,197
