Introduzione
If the LCD screen is damaged or broken, you may want to remove it and repair or replace it.
Parti
Nessuna parte richiesta.
Open the battery cover.
  • Open the battery cover.
Aggiungi Commento
Slide the orange latch sideways to eject the battery.
  • Slide the orange latch sideways to eject the battery.
  • Remove the battery.
Aggiungi Commento
Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
  • Remove 7 screws.
    • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
    • 4 (4.45mm) screws on the bottom of the camera.
    • 2 (2.95mm) screws on the left side of the camera.
Aggiungi Commento
There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
Aggiungi Commento
Remove the rear camera casing. Remove the front casing.
  • Remove the rear camera casing.
  • Remove the front casing.
Aggiungi Commento
Flip up the LCD screen to reveal the two orange ribbon cables. Disconnect the two ribbons cables from their sockets on the motherboard. Disconnect the two ribbons cables from their sockets on the motherboard.
  • Flip up the LCD screen to reveal the two orange ribbon cables.
  • Disconnect the two ribbons cables from their sockets on the motherboard.
Aggiungi Commento
Conclusione
Cal Poly, Team 2-8, Johann Summer 2010 Membro di Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,125
