Introduzione
Use this guide to remove the memory card
Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open so be careful to lift it up gently.
  • Position the camera with the bottom facing up.
  • With your finger, slide the battery cover in the direction of open arrow.
  • The battery cover will spring open so be careful to lift it up gently.
Aggiungi Commento
Push down on the memory card and it will spring up. Grip and pull up the memory card to remove it.
  • Push down on the memory card and it will spring up.
  • Grip and pull up the memory card to remove it.
Aggiungi Commento
Conclusione
Dustin Rodgers
Membro da: 05/10/2010
50 Reputazione
4 Guide realizzate
Cal Poly, Team 7-51, Amido Fall 2010 Membro di Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,047
