Introduzione
The ribbon cable connects the logic board to the motor. It looks like a gray ribbon with a red stripe.
Parti
Nessuna parte richiesta.
Remove the glass container and place the blender upside down on a solid surface. Remove the four rubber feet using the needle nose pliers. Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  • Remove the glass container and place the blender upside down on a solid surface.
  • Remove the four rubber feet using the needle nose pliers.
  • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
Aggiungi Commento
Lift the back panel up, sliding it along the power cord.
  • Lift the back panel up, sliding it along the power cord.
Aggiungi Commento
Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver. Remove the rubber O-ring by lifting it up.
  • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
  • Remove the rubber O-ring by lifting it up.
Aggiungi Commento
Remove the ribbon cable from the chassis by lifting it up.
  • Remove the ribbon cable from the chassis by lifting it up.
  • Remove the other end of the ribbon cable from the circuit board by lifting it up.
Aggiungi Commento
Conclusione
Cameron Geehr
Membro da: 28/09/2014
681 Reputazione
6 Guide realizzate
Cal Poly, Team 12-5, Forte Fall 2014 Membro di Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 221
