Salta al contenuto principale
KitchenAid KSB5CR Back Panel Removal
Cosa ti serve
  1. KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: passo 1, immagine 1 di 3 KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: passo 1, immagine 2 di 3 KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: passo 1, immagine 3 di 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 2: passo 2, immagine 1 di 1
    • Lift the back panel up, sliding it along the power cord.
Conclusione
Cal Poly, Team 12-5, Forte Fall 2014 Membro di Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 603
