Introduzione
Use this guide to help you replace the speakers in the Amazon Kindle Fire.
Cosa ti serve
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
Peel the tape on the upper-left IC that is securing the speaker cable.
Use the flat end of a spudger to push the speaker connector out of its socket.
Deroute the speaker cable.
Altre 3 persone hanno completato questa guida.
2 Commenti
I replaced the speakers and now my screen is black. I hear sounds but no picture. Any suggestions???
