Introduzione
Use this guide to help you replace the LCD in an Amazon Kindle Fire.
Cosa ti serve
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
Peel the tape on the upper-left IC that is securing the speaker cable.
Use the flat end of a spudger to push the speaker connector out of its socket.
Deroute the speaker cable.
Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
Use a plastic opening tool to release the touchscreen controller connector.
Gently remove the touchscreen controller by lifting it up and to the right.
Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
Lever the top side of the motherboard up with a plastic opening tool until it comes free.
Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
Lift the power button board out of the Kindle Fire.
Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
Slide the ambient light sensor out from under the frame and remove it from the Kindle Fire.
Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand.
Remove the frame from the display assembly.
Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel.
Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture.
Separate the LCD and front glass panel.
Altre 22 persone hanno completato questa guida.
2 Commenti
Is the LCD the same thing as the digitizer? My touch screen is really glitchy and I did a hard reset and a factory reset and I’m still having trouble. I’m trying to decide what I need to replace?
No, the digitizer is the glass itself. The only thing the lcd does is display things.
