Cosa ti serve
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Lift up until you hear a slight popping noise.
Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
Altre 2 persone hanno completato questa guida.
