Introduzione
There are a few layers that you have to work through to get to the inside of the Kid Galaxy Explorer. There are screws on the top and bottom holding the Kid Galaxy Explorer together so if it is not coming apart do not pry it open; check for more screws.
Parti
Nessuna parte richiesta.
First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
Aggiungi Commento
After the screw has been loosened, lift the cover off.
  • After the screw has been loosened, lift the cover off.
Aggiungi Commento
Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
Aggiungi Commento
After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
  • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
  • Turn the RC car over to reach the six screws on the bottom.
Aggiungi Commento
Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
  • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
  • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
Aggiungi Commento
Lift the top Cover off the car.
  • Lift the top Cover off the car.
Aggiungi Commento
Conclusione
USF Tampa, Team 1-2, Hickman Fall 2014 Membro di USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Membri
7 Guide realizzate
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
Dishant Patel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 103
