Strumenti
Nessun attrezzo richiesto.
Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
Aggiungi Commento
Remove the wheels by pulling them away from the RC car.
  • Remove the wheels by pulling them away from the RC car.
Aggiungi Commento
Make note of where each driving gear cover is placed. They only go in one way.
  • Make note of where each driving gear cover is placed. They only go in one way.
  • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
Aggiungi Commento
Pry open the two gear covers on both sides.
  • Pry open the two gear covers on both sides.
Aggiungi Commento
Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
Aggiungi Commento
Slide both axles from the internal axles guides within the car.
  • Slide both axles from the internal axles guides within the car.
  • Reverse the steps to replace the axles.
Aggiungi Commento
Conclusione
Rusbell Gonzalez
Membro da: 17/09/2014
219 Reputazione
5 Guide realizzate
USF Tampa, Team 1-2, Hickman Fall 2014 Membro di USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 123
