Salta al contenuto principale
Keurig Mini B-31 K-cup Holder Replacement
Cosa ti serve
  1. Keurig Mini B-31 K-cup Holder Replacement, K-cup holder: passo 1, immagine 1 di 1
    • Lift up the handle of the Keurig Mini.
  2. Keurig Mini B-31 K-cup Holder Replacement: passo 2, immagine 1 di 2 Keurig Mini B-31 K-cup Holder Replacement: passo 2, immagine 2 di 2
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
  3. Keurig Mini B-31 K-cup Holder Replacement: passo 3, immagine 1 di 2 Keurig Mini B-31 K-cup Holder Replacement: passo 3, immagine 2 di 2
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
  4. Keurig Mini B-31 K-cup Holder Replacement: passo 4, immagine 1 di 1
    • Pull the K-cup holder straight out.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team 17-1, Forte Winter 2014 Membro di Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Membri
17 Guide realizzate
2 Commenti
Press up on the outlet of the holder to push it out. This is covered in the manufacturer’s user manual which comes with the unit when new.
jastpeel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 12,747
