Introduzione
Disassemble the gear to replace the "Vertical Drive Shaft" and the "Planet Hub"
Knob can be pulled away
  • Knob can be pulled away
  • Take care of the white rubber piece
Aggiungi Commento
Loosen hex nut Pull "Planetary Hub" straight away
  • Loosen hex nut
  • Pull "Planetary Hub" straight away
  • Loosen Torx screws holding the lower housing
Aggiungi Commento
Take away lower housing Rubber can be taken away for cleaning
  • Take away lower housing
  • Rubber can be taken away for cleaning
  • Take away damping lint
Aggiungi Commento
Unscrew to take away the plastic parts The parts are different
  • Unscrew to take away the plastic parts
  • The parts are different
  • The screws have no metric thread
Aggiungi Commento
Unscrew the 3 Torx Lift off the Upper Housing
  • Unscrew the 3 Torx
  • Lift off the Upper Housing
  • Take care of white rubber marked with the red square
Aggiungi Commento
According to "Jens" the plastic wheel can be removed by turnig it counter-clockwise when the gear is blocked. "Julien" found a YouTube-Video showing how to proceed. Starting at 7:25. Thank you to Jens and Julien. No need to proceed with the custom tool if the plastic wheel has already been removed in the previous step
  • According to "Jens" the plastic wheel can be removed by turnig it counter-clockwise when the gear is blocked. "Julien" found a YouTube-Video showing how to proceed. Starting at 7:25. Thank you to Jens and Julien.
  • No need to proceed with the custom tool if the plastic wheel has already been removed in the previous step
  • The tricky part is to unscrew the Tx20 screw located under the plastic wheel
  • I was not able to pull the plastic wheel from the shaft
  • If you like the risk you might drill a hole in the plastic wheel for easy access
  • I used a custom tool -> see next step
I found this disassembly on YouTube: starting at 7:25 you will find a clear demonstration on how to remove the plastic wheel from the shaft without drilling or improvised tools. You don’t even have to understand Italian :-)
Julien - Replica
I machined a 6 mm wrench to fit on the Tx20 bit After removal I slotted the screw for easier mounting After removal I slotted the screw for easier mounting
  • I machined a 6 mm wrench to fit on the Tx20 bit
  • After removal I slotted the screw for easier mounting
Aggiungi Commento
Take care of the guides (red markers). They can be pushed in after closing the gear box Take away the sealing. To reseal I used sealant normally used in washing rooms.
  • Take care of the guides (red markers). They can be pushed in after closing the gear box
  • Take away the sealing. To reseal I used sealant normally used in washing rooms.
Aggiungi Commento
The one with the cross is the old one The bayonet doesn't look the same but the tools fits as before. The position of beater and whisk stay the same in respect to the bowl The thickness change of the gearwheel doesn't seem to matter
  • The one with the cross is the old one
  • The bayonet doesn't look the same but the tools fits as before. The position of beater and whisk stay the same in respect to the bowl
  • The thickness change of the gearwheel doesn't seem to matter
Aggiungi Commento
The one with the cross is the old one The one with the cross is the old one The one with the cross is the old one
Aggiungi Commento
Cod. SER1018: Label of the bag containing the tree parts Label of "Planet Hub" Label and part designated "Planet Hub Nut"
  • Cod. SER1018: Label of the bag containing the tree parts
  • Label of "Planet Hub"
  • Label and part designated "Planet Hub Nut"
Aggiungi Commento
Put each gearwheel on its axle Take care of the two washers Take care of the two washers
  • Put each gearwheel on its axle
  • Take care of the two washers
Aggiungi Commento
There is plenty of grease. Put it on the parts to be greased. Put sealant on the box (see step 8)
  • There is plenty of grease. Put it on the parts to be greased.
  • Put sealant on the box (see step 8)
  • Place the machine upright standing in the normal working position with lowered arm. The front axle will fall out if the arm is in the upper position.
  • Gently slip the lower part in the upper part
  • As the screws were loose when disassembling, I put a drop of thread locker before mounting.
  • Mount the guides in the correct place
Aggiungi Commento
Insert hidden screw
  • Insert hidden screw
  • Tighten with custom tool of step 7
Hello, this is a nice fixit. Step 6 and step 14 are wrong. Normaly you have only to block the slow-speed outlet with KW658479, a steel-pulley. This works also for all other kenwood's since A901 series both Chef and Major . You only need to block the slow-speed then turn the the plastic-wheel counter-clockwise to remove it now the screw is free to unscrew.
It is much easier and shorter.
Hope it will help somebody to fix another Kenwood chef or Major or cooking-chef
jens - Replica
Hi Jens, Thank you for the information. The guides were modified according to your suggestion.
Bruno M -
Conclusione
To reassemble your device, follow these instructions in reverse order at step 6.
Bruno M
Membro da: 14/02/2015
401 Reputazione
3 Guide realizzate
Hello,
I was not able to realise the suggestion of "Jens" in step 6. Maybe it works on older machines (A901), but it did not work on my Chef Titanium KM001 which has the same gear as the one depicted herein. I chose to make a hole in the plastic wheel instead, using a Dremel at with a corundum tip, after marking the right distance from the center with a pe n by applying the pen from below at the same distance as the screw and rotating the plastic wheel. The The TX 20 screw came off just fine and without fiddling around. The machine turns again. Note: I had not put enough grease inside, and it didn't sound so good. I therefore added additional lube via the hole under the red stopper, and everything was fine (no need to disassemble the machine again).
doems2be - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 60
Tutti i Tempi: 2,771
