Salta al contenuto principale
Kenmore 110 Series Washing Machine Water Pump Replacement
Cosa ti serve
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: passo 1, immagine 1 di 1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, immagine 1 di 3 Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, immagine 2 di 3 Kenmore 110 Series Washing Machine Water Pump Replacement: passo 2, immagine 3 di 3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Conclusione
Altre 14 persone hanno completato questa guida.
Robert Trout
Membro da: 09/26/12
1.234 Reputazione
5 Guide realizzate
Cal Poly, Team 15-43, Forte Fall 2012 Membro di Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Membri
11 Guide realizzate
9 Commenti
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Replica
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Replica
My clothes are still really wet.
Tracy Schultz - Replica
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 344
Tutti i Tempi: 58,783
