Introduzione
This guide will aid the user in the installation of a new case for this device. The new case will include the front case, the back case, and the battery cover flap. This guide will require the user to remove all of the internal parts of the device. This guide should be used if the case gets cracked, scratched, or otherwise damaged in some way.
Cosa ti serve
Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
