Salta al contenuto principale
Jabra CRUISER2 Motherboard Replacement
Cosa ti serve
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: passo 1, immagine 1 di 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Istruzioni iOpener
  2. Jabra CRUISER2 Motherboard Replacement: passo 2, immagine 1 di 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: passo 3, immagine 1 di 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 Jabra CRUISER2 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: passo 5, immagine 1 di 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the motherboard from the device by lifting it up from the back plate.
Conclusione
Spartacus
Membro da: 10/17/14
636 Reputazione
5 Guide realizzate
Baylor, Team 8-13, Williams Fall 2014 Membro di Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 773
