Salta al contenuto principale
JVC Adixxion GC-XA1BU Battery Cover Replacement
Cosa ti serve
  1. JVC Adixxion GC-XA1BU Battery Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 2, immagine 1 di 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 3, immagine 1 di 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 4, immagine 1 di 2 JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 4, immagine 2 di 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Battery Cover Replacement: passo 5, immagine 1 di 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Battery Cover Replacement, Battery Cover: passo 6, immagine 1 di 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
Conclusione
USF Tampa, Team 1-2, Tanski Winter 2015 Membro di USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,251
