Introduzione
This guide will provide instructions on how to replace the motherboard.
Turn the phone off by holding down the power button located on the top of the phone.
  • Turn the phone off by holding down the power button located on the top of the phone.
Aggiungi Commento
Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool. Gently remove the back case completely from the phone. Gently remove the back case completely from the phone.
  • Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
  • Gently remove the back case completely from the phone.
Aggiungi Commento
Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward. Remove the battery from the phone. When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
  • Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
  • Remove the battery from the phone.
  • When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
Aggiungi Commento
With the phone lying face down, remove the nine 3 mm Phillips #00 screws from the midframe. Gently run a plastic opening tool down along the left and right sides of the phone to separate the black midframe assembly from the silver display casing. Carefully remove the midframe assembly from the display casing by pulling up and away from the phone.
  • With the phone lying face down, remove the nine 3 mm Phillips #00 screws from the midframe.
  • Gently run a plastic opening tool down along the left and right sides of the phone to separate the black midframe assembly from the silver display casing.
  • Carefully remove the midframe assembly from the display casing by pulling up and away from the phone.
  • The motherboard is housed between the screen/display casing and the midframe assembly. Removal of the screen is not necessary to access the motherboard.
Aggiungi Commento
Using a precision tweezer, remove the protective stickers from the connectors. Using a precision tweezer or spudger, carefully slide the indicated connectors out from their ports on the motherboard.
  • Using a precision tweezer, remove the protective stickers from the connectors.
  • Using a precision tweezer or spudger, carefully slide the indicated connectors out from their ports on the motherboard.
Aggiungi Commento
Locate the two white clips along the edge of the phone that hold the motherboard in place. Using a finger or plastic opening tool, pull the clips away from the motherboard and hold the clips back. Wedge a plastic credit card or opening pick underneath the motherboard to separate the motherboard away from the display casing.
  • Locate the two white clips along the edge of the phone that hold the motherboard in place.
  • Using a finger or plastic opening tool, pull the clips away from the motherboard and hold the clips back.
  • Wedge a plastic credit card or opening pick underneath the motherboard to separate the motherboard away from the display casing.
  • Carefully lift the motherboard upward, making sure any remaining tape connectors are detached.
  • Tip: Use one finger to hold one clip open and a small plastic opening tool to hold the other clip open while simultaneously prying the motherboard from the display case (see photo 1)
Aggiungi Commento
Conclusione
Delilah
Membro da: 08/10/2014
182 Reputazione
1 Guida realizzata
USF Tampa, Team 9-4, Leahy Fall 2014 Membro di USF Tampa, Team 9-4, Leahy Fall 2014
USFT-LEAHY-F14S9G4
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 817
