Introduzione
This guide will provide instructions on how to remove the back case and replace the battery.
Parti
Nessuna parte richiesta.
Turn the phone off by holding down the power button located on the top of the phone.
  • Turn the phone off by holding down the power button located on the top of the phone.
Aggiungi Commento
Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool. Gently remove the back case completely from the phone. Gently remove the back case completely from the phone.
  • Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
  • Gently remove the back case completely from the phone.
Aggiungi Commento
Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward. Remove the battery from the phone. When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
  • Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
  • Remove the battery from the phone.
  • When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
Aggiungi Commento
Conclusione
Samantha Fruge
Membro da: 08/10/2014
231 Reputazione
2 Guide realizzate
USF Tampa, Team 9-4, Leahy Fall 2014 Membro di USF Tampa, Team 9-4, Leahy Fall 2014
USFT-LEAHY-F14S9G4
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 356
