Introduzione
The T-Bar allows you to steer and control your scooter. This guide will show the replacement of a T-Bar.
Parti
Nessuna parte richiesta.
Unlock the quick-release lever by turning the lever from a tightened position. Unlock the quick-release lever by turning the lever from a tightened position.
  • Unlock the quick-release lever by turning the lever from a tightened position.
Aggiungi Commento
Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown. Be sure to fasten the opposite side of the screw before unscrewing. Remove the screw and note the order of the parts for reassembly.
  • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
  • Be sure to fasten the opposite side of the screw before unscrewing.
  • Remove the screw and note the order of the parts for reassembly.
Aggiungi Commento
Turn the quick-release lever over to reveal an 8mm screw. Use the Phillips #2 screw driver to remove the screw. After removing the screw, the circular latch will be detachable.
  • Turn the quick-release lever over to reveal an 8mm screw.
  • Use the Phillips #2 screw driver to remove the screw.
  • After removing the screw, the circular latch will be detachable.
Aggiungi Commento
After disassembling the Quick-Release Lever, the T-Bar is removable
  • After disassembling the Quick-Release Lever, the T-Bar is removable
Aggiungi Commento
Conclusione
Shane
Membro da: 18/10/2014
358 Reputazione
3 Guide realizzate
Cal Poly, Team 4-46, Amido Fall 2014 Membro di Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 177
