Salta al contenuto principale
JD Razor 2000 Shocks Replacement
Cosa ti serve
  1. JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: passo 1, immagine 1 di 3 JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: passo 1, immagine 2 di 3 JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: passo 1, immagine 3 di 3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Shocks Replacement, Removing the Wheel: passo 2, immagine 1 di 1
    • Grip the bottom of the wheel and gently slide it out.
  3. JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: passo 3, immagine 1 di 3 JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: passo 3, immagine 2 di 3 JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: passo 3, immagine 3 di 3
    • Find the axle bolt behind the shocks. It should look similar to the one used to remove the front wheel.
    • Remove the bolt in the same manner as the wheel. While applying pressure to the left side, unscrew the right using an Allen wrench.
    • If the left side of the bolt rotates when you attempt to unscrew the right, use a second Allen wrench to hold it in place.
    • If the bolt does not turn at all or does not turn easily, apply lubricant to the screw and try again in five minutes.
    • Remove the bolt and bearing and the black rubber stoppers. Remove the metal tube between the bolt.
  4. JD Razor 2000 Shocks Replacement, Removing the Wheel Holder and Shock: passo 4, immagine 1 di 2 JD Razor 2000 Shocks Replacement, Removing the Wheel Holder and Shock: passo 4, immagine 2 di 2
    • Firmly grasp the metal piece that holds the wheel and gently pull it away.
    • The shocks should fall out naturally by themselves. This is normal and expected. If they do not, gently pull the shocks out of their holders.
    • A metal cylinder is located inside the spring of the shock. Do not lose this.
Conclusione
Cal Poly, Team 4-46, Amido Fall 2014 Membro di Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,850
