Introduzione
Unresponsive Play/Pause Button? Need to switch it out? This guide will show you how to remove the Play/Pause Button. This guide has a few tricky parts, but if you follow along you should have it off in no time.
Parti
Nessuna parte richiesta.
Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
Aggiungi Commento
Detach the back cover by carefully pulling up and out on the back plastic casing. Do not pull apart the red wire connecting the battery to the device.
  • Detach the back cover by carefully pulling up and out on the back plastic casing.
  • Do not pull apart the red wire connecting the battery to the device.
Aggiungi Commento
Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
  • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
  • Be careful to not tear the wires while opening the case.
Aggiungi Commento
Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
  • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
  • Do not disconnect wires from plastic connector.
Aggiungi Commento
Remove the four corner plastic covers on the back of the device using the plastic opening tool. Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
Aggiungi Commento
Using a Philips #00 screwdriver remove all four 4.5mm  corner screws located underneath the corner pads.
  • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
Aggiungi Commento
Carefully wedge the plastic opening tool into either long side of the device. Slowly move the plastic opening tool along the side of the device, separating the front and back case covers. Repeat these steps on the other side of the device.
  • Carefully wedge the plastic opening tool into either long side of the device.
  • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
  • Repeat these steps on the other side of the device.
Aggiungi Commento
Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Aggiungi Commento
Remove the white plastic ring from around the scroll wheel using your fingers.
  • Remove the white plastic ring from around the scroll wheel using your fingers.
Aggiungi Commento
Insert the plastic opening tool underneath any side of the scroll wheel. Slowly lift up on the plastic opening tool and the scroll wheel will come off. Slowly lift up on the plastic opening tool and the scroll wheel will come off.
  • Insert the plastic opening tool underneath any side of the scroll wheel.
  • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
Aggiungi Commento
Slightly insert plastic opening tool underneath any side of the play button.
  • Slightly insert plastic opening tool underneath any side of the play button.
Aggiungi Commento
Lift up slowly with the plastic opening tool and the play button should pop off. Lift up slowly with the plastic opening tool and the play button should pop off.
  • Lift up slowly with the plastic opening tool and the play button should pop off.
Aggiungi Commento
Conclusione
Wesley Ballar
Membro da: 18/04/2013
88 Reputazione
4 Guide realizzate
Cal Poly, Team 12-36, Amido Spring 2013 Membro di Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 166
