Introduzione
This guide shows you how to replace a broken display on the Insignia NS-CLIP02. The device should be physically unplugged, not just “switched off.” If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
Cosa ti serve
Set the clock radio on the work space so the bottom of the device is showing.
Using the Phillips screwdriver, remove the three screws that run along the center of the base.
