Parti
Nessuna parte richiesta.
Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
  • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
  • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
  • Once the screws have been removed, proceed to take off back cover.
Aggiungi Commento
Now, proceed to lift the battery out and remove it.
  • Now, proceed to lift the battery out and remove it.
Aggiungi Commento
Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
  • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
Aggiungi Commento
Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
  • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
Aggiungi Commento
Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary. Pull the motherboard out and down away from the top of the phone.
  • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
  • Pull the motherboard out and down away from the top of the phone.
Aggiungi Commento
Conclusione
Lauren
Membro da: 13/02/2014
43 Reputazione
2 Guide realizzate
Ohio State, Team 1-4, Buehl Spring 2014 Membro di Ohio State, Team 1-4, Buehl Spring 2014
OSU-BUEHL-S14S1G4
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 378
