Salta al contenuto principale
InFocus LP540 Projector Main Fans Replacement
Cosa ti serve
  1. InFocus LP540 Projector Main Fans Replacement, Main Board: passo 1, immagine 1 di 3 InFocus LP540 Projector Main Fans Replacement, Main Board: passo 1, immagine 2 di 3 InFocus LP540 Projector Main Fans Replacement, Main Board: passo 1, immagine 3 di 3
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Main Fans Replacement: passo 2, immagine 1 di 2 InFocus LP540 Projector Main Fans Replacement: passo 2, immagine 2 di 2
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Main Fans Replacement: passo 3, immagine 1 di 3 InFocus LP540 Projector Main Fans Replacement: passo 3, immagine 2 di 3 InFocus LP540 Projector Main Fans Replacement: passo 3, immagine 3 di 3
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Main Fans Replacement: passo 4, immagine 1 di 2 InFocus LP540 Projector Main Fans Replacement: passo 4, immagine 2 di 2
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Main Fans Replacement: passo 5, immagine 1 di 3 InFocus LP540 Projector Main Fans Replacement: passo 5, immagine 2 di 3 InFocus LP540 Projector Main Fans Replacement: passo 5, immagine 3 di 3
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Main Fans Replacement: passo 6, immagine 1 di 3 InFocus LP540 Projector Main Fans Replacement: passo 6, immagine 2 di 3 InFocus LP540 Projector Main Fans Replacement: passo 6, immagine 3 di 3
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
  7. InFocus LP540 Projector Main Fans Replacement, Main Fans: passo 7, immagine 1 di 2 InFocus LP540 Projector Main Fans Replacement, Main Fans: passo 7, immagine 2 di 2
    • Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
Conclusione
Cal Poly, Team 13-17, Regan Winter 2014 Membro di Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,392
