Introduzione
A dull or broken string can greatly depreciate the sound that a guitar produces. This guide will give you a step by step procedure of how to remove and replace an old or broken string.
Turn the peg in the direction of less resistance. The string should become more slacked or droopy.
  • Turn the peg in the direction of less resistance. The string should become more slacked or droopy.
Aggiungi Commento
When the string is very loose and is no longer coiled around the peg, slide it through the hole in the peg to remove it from the head.
  • When the string is very loose and is no longer coiled around the peg, slide it through the hole in the peg to remove it from the head.
Aggiungi Commento
Using the all-in-one tool, slide the peg between the groove and gently lift up until the peg comes out.
  • Using the all-in-one tool, slide the peg between the groove and gently lift up until the peg comes out.
Aggiungi Commento
With your new string, align the nut end with the groove in the bridge pin so that the nut is at the opposite side of the head of the pin. With your new string, align the nut end with the groove in the bridge pin so that the nut is at the opposite side of the head of the pin.
  • With your new string, align the nut end with the groove in the bridge pin so that the nut is at the opposite side of the head of the pin.
Aggiungi Commento
Slide both the string and the bridge pin back into the hole,(make sure the groove is facing the string) and then when in place, apply a small amount of force with your thumb until you hear it click into place. Slide both the string and the bridge pin back into the hole,(make sure the groove is facing the string) and then when in place, apply a small amount of force with your thumb until you hear it click into place.
  • Slide both the string and the bridge pin back into the hole,(make sure the groove is facing the string) and then when in place, apply a small amount of force with your thumb until you hear it click into place.
Aggiungi Commento
Thread the end of the new string through the hole of the peg, but don't pull it all the way tight, leave the string loose on the neck.
  • Thread the end of the new string through the hole of the peg, but don't pull it all the way tight, leave the string loose on the neck.
Aggiungi Commento
With the new string loose on the neck, tighten the peg so the string winds in the same direction as the other strings and wind it until it is tight and does not wobble. Make sure the string is aligned with the groove in the neck. With the new string loose on the neck, tighten the peg so the string winds in the same direction as the other strings and wind it until it is tight and does not wobble. Make sure the string is aligned with the groove in the neck. With the new string loose on the neck, tighten the peg so the string winds in the same direction as the other strings and wind it until it is tight and does not wobble. Make sure the string is aligned with the groove in the neck.
  • With the new string loose on the neck, tighten the peg so the string winds in the same direction as the other strings and wind it until it is tight and does not wobble. Make sure the string is aligned with the groove in the neck.
Aggiungi Commento
Using guitar string cutters, leave between a quarter inch to half of an inch of string so the excess string does not get in the way.
  • Using guitar string cutters, leave between a quarter inch to half of an inch of string so the excess string does not get in the way.
Aggiungi Commento
Conclusione
Follow the instructions for any broken or dull strings that need replacing.
Kevin Petri
Membro da: 14/10/2014
141 Reputazione
1 Guida realizzata
USF Tampa, Team 1-26, Donnelly Fall 2014 Membro di USF Tampa, Team 1-26, Donnelly Fall 2014
USFT-DONNELLY-F14S1G26
1 Membro
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 382
