Parti
Nessuna parte richiesta.
Turn the computer over so that the back is facing upwards.
  • Turn the computer over so that the back is facing upwards.
  • Locate the screw in the bottom left-hand corner of the computer.
Aggiungi Commento
Using a #0 Phillips screwdriver, remove the 17 mm screw.
  • Using a #0 Phillips screwdriver, remove the 17 mm screw.
Aggiungi Commento
Carefully remove the plastic piece covering the hard drive by first pulling up then away  from the computer.
  • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
Aggiungi Commento
Locate the folded black tab within the hard drive port. With a screwdriver, pull the black tab out of the slot.
  • Locate the folded black tab within the hard drive port.
  • With a screwdriver, pull the black tab out of the slot.
Aggiungi Commento
Pull gently on the black tab and the metal tray holding the hard drive will slide out. Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
Aggiungi Commento
Remove the plastic coverings on both sides of the hard drive.
  • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Kyle
Membro da: 18/04/2013
249 Reputazione
8 Guide realizzate
Cal Poly, Team 8-58, Johann Spring 2013 Membro di Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 57
Tutti i Tempi: 2,662
