Introduzione
This guide will show how to remove a failing touchpad from the palm rest of an IBM Thinkpad T60. Remember to always power down the computer before attempting any installation/removal of any hardware components. Be sure to remove the AC adapter and all cables from the computer. If the computer has been on, wait several minutes before beginning the procedure to ensure all parts have cooled down.
Cosa ti serve
Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
Use your finger to slide the tab to the right to unlock the battery.
2 Commenti
I bought mine used on eBay. and upgraded the HDD and RAM and it is working perfectly. But I recently noticed that the palm rest is not perfectly seated at the front edge and is raised by roughly 2mm. (⅛in.) I have tried refitting the palm rest, but it hasn’t made any different. It is possible that it was like that before I fitted the RAM and I just hadn’t notice, so it could be the result of an earlier intervention. The machine still works OK and the lid closes, so it isn’t a big deal, but it is a bit annoying that such a well engineered device doesn’t go back together exactly as it should. Any suggestions?
Sort of solved it . . . . . Get the left hand side located first and jiggle it about a bit and the palm rest will fit back neatly. But it isn’t immediately obvious how you shouls go about this.
