Salta al contenuto principale
IBM Thinkpad T60 Palm Rest Replacement
Cosa ti serve
  1. IBM Thinkpad T60 Palm Rest Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 Palm Rest Replacement: passo 2, immagine 1 di 2 IBM Thinkpad T60 Palm Rest Replacement: passo 2, immagine 2 di 2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 Palm Rest Replacement, Palm Rest: passo 3, immagine 1 di 2 IBM Thinkpad T60 Palm Rest Replacement, Palm Rest: passo 3, immagine 2 di 2
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
  4. IBM Thinkpad T60 Palm Rest Replacement: passo 4, immagine 1 di 1
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 Palm Rest Replacement: passo 5, immagine 1 di 2 IBM Thinkpad T60 Palm Rest Replacement: passo 5, immagine 2 di 2
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
    • Detach the connector by pulling upwards on the white tab.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 7-9, Maness Winter 2013 Membro di Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Membri
16 Guide realizzate
Un commento
Needs a tutorial on how to install it. I can’t get the palmrest on correctly, I can still lift up on the palmrest and the laptop doesn’t latch properly.
Kyle Gilchrist - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,195
