Salta al contenuto principale
IBM ThinkPad T42 RAM Replacement
Cosa ti serve
  1. IBM ThinkPad T42 RAM Replacement, Battery Clips: passo 1, immagine 1 di 1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Unscrew the pictured screwed holding the memory cover in place.
  4. IBM ThinkPad T42 RAM Replacement: passo 4, immagine 1 di 1
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
    • Pull the stick out carefully.
    • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
Conclusione
Altre 7 persone hanno completato questa guida.
Kevin Rehm
Membro da: 04/19/10
472 Reputazione
4 Guide realizzate
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
35 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 7,076
