Introduzione
Replacing the fan.
Parti
Nessuna parte richiesta.
Unscrew the 20 Phillips screws on the underside of the T42.
  • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
Aggiungi Commento
Unscrew the 2 Phillips screws on both sides of the T42's rear.
  • Unscrew the 2 Phillips screws on both sides of the T42's rear.
leave these four screws alone. No need to remove them.
fredwb - Replica
Of course you need to remove them you Dingbat! They are the main anchors of the screen hinges, Doh!
wbcam -
There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
The dark red circles are not very easy to see. How about white ones?
mattikaki - Replica
Flip the laptop over and open the screen.
  • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
Aggiungi Commento
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
Aggiungi Commento
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed. Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
  • Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
Aggiungi Commento
The metal bracket will now be free to move, grasp it and remove it from the device. The metal bracket will now be free to move, grasp it and remove it from the device.
  • The metal bracket will now be free to move, grasp it and remove it from the device.
Aggiungi Commento
Remove the small rubber piece that is covering the T42's microphone,
  • Remove the small rubber piece that is covering the T42's microphone,
Aggiungi Commento
Unscrew the 3 screws on the copper heatsink. Now, unplug the connection to the motherboard..
  • Unscrew the 3 screws on the copper heatsink.
  • Now, unplug the connection to the motherboard..
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Kevin Rehm
Membro da: 19/04/2010
376 Reputazione
8 Guide realizzate
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
30 Guide realizzate
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 39
Tutti i Tempi: 23,056
