Introduzione
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its wireless network card.
Parti
Nessuna parte richiesta.
Close the screen and turn the closed laptop over.
  • Close the screen and turn the closed laptop over.
  • Remove all 17 screws on the bottom of the computer.
  • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
  • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
You need to remove the battery, hard drive, and UltraDrive before starting step 1.
cak - Replica
Remove the extra RAM cover, by lifting where the screw was and pulling out.
  • Remove the extra RAM cover, by lifting where the screw was and pulling out.
If there's extra RAM under the cover, remove it by spreading the retaining clips.
cak - Replica
Turn the laptop right side up and open the screen.
  • Turn the laptop right side up and open the screen.
  • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
  • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
Aggiungi Commento
Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
  • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
  • Remove the keyboard.
Aggiungi Commento
Close the laptop and turn it over.
  • Close the laptop and turn it over.
  • Remove the five plastic stickers covering the screws on the front edge of the case.
  • In order to reuse the stickers, remove them carefully.
Aggiungi Commento
Unscrew the five screws that were hidden by the stickers.
  • Unscrew the five screws that were hidden by the stickers.
Aggiungi Commento
Turn the computer right side up and open the screen.
  • Turn the computer right side up and open the screen.
  • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
  • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
Aggiungi Commento
Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
Aggiungi Commento
Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
  • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
Aggiungi Commento
Push apart the retaining clips.
  • Push apart the retaining clips.
  • Note: The card should pop up a little bit.
Aggiungi Commento
Pull the wireless network card out.
  • Pull the wireless network card out.
Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Marissa Blustein
Membro da: 16/04/2010
414 Reputazione
24 Guide realizzate
Cal Poly, Team 7-8, Maness Spring 2010 Membro di Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 32
Tutti i Tempi: 31,205
