Salta al contenuto principale
IBM ThinkPad T41 Screen Replacement
Cosa ti serve
  1. IBM ThinkPad T41 Screen Replacement, Keyboard: passo 1, immagine 1 di 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. IBM ThinkPad T41 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. IBM ThinkPad T41 Screen Replacement: passo 3, immagine 1 di 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 Screen Replacement: passo 4, immagine 1 di 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 Screen Replacement, Trackpad: passo 5, immagine 1 di 1
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. IBM ThinkPad T41 Screen Replacement: passo 6, immagine 1 di 1
    • Unscrew the five screws that were hidden by the stickers.
  7. IBM ThinkPad T41 Screen Replacement: passo 7, immagine 1 di 1
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  8. IBM ThinkPad T41 Screen Replacement: passo 8, immagine 1 di 1
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  9. IBM ThinkPad T41 Screen Replacement, Wireless Network Card: passo 9, immagine 1 di 1
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
  10. IBM ThinkPad T41 Screen Replacement: passo 10, immagine 1 di 1
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
  11. IBM ThinkPad T41 Screen Replacement: passo 11, immagine 1 di 1
    • Pull the wireless network card out.
  12. IBM ThinkPad T41 Screen Replacement, Screen: passo 12, immagine 1 di 1
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
  13. IBM ThinkPad T41 Screen Replacement: passo 13, immagine 1 di 1
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
  14. IBM ThinkPad T41 Screen Replacement: passo 14, immagine 1 di 1
    • Remove a single screw from the metal plate that secures the display cable.
  15. IBM ThinkPad T41 Screen Replacement: passo 15, immagine 1 di 1
    • Pull the metal plate away from the display cable.
  16. IBM ThinkPad T41 Screen Replacement: passo 16, immagine 1 di 1
    • Disconnect the display cable.
  17. IBM ThinkPad T41 Screen Replacement: passo 17, immagine 1 di 1
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
  18. IBM ThinkPad T41 Screen Replacement: passo 18, immagine 1 di 1
    • Lift out the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 7-8, Maness Spring 2010 Membro di Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 18,547
