Introduzione
In this guide, you will learn how to remove and replace a hard drive for an IBM ThinkPad T30 laptop. The laptop comes with an IDE / PATA Hard disk drive that is either 20/40/60GB and is easy to remove only using a few tools
Cosa ti serve
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Flip to the back of the Thinkpad.
Remove the single 11 mm screw using the Phillips #0 screwdriver.
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
Altre 11 persone hanno completato questa guida.
